allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
cliff344
Oct 28, 2019Apprentice
It is truly a shame that Netgear doesn’t spend more time proving out these routers in house or by beta testing prior to releasing. What amazes me even more are features like media server that hasn’t worked reliably on any of the 6 different Netgear’s I’ve owned yet it’s still part of the GUI and firmware. It almost seems like they just take the same GUI firmware and try and adapt it and make it work for all the new routers, instead of taking the time to build them from the ground up for each device. How is it that individual developers who develop firmware such as DD-WRT can make it so much better on a small budget, yet Netgear which I am sure is a multi-million dollar company can’t sell you a better product off the shelf without these types of issues?
PDWhite
Jan 29, 2020Apprentice
Hit apply.
