allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
mafo5000
Mar 06, 2020Tutor
I tried incorperating everyones suggestions and most of them, unfortuntaley, made the router perform worse than before. Turning off smart connect did help but (only slightly) not enough for me to keep the router. I've been messing with this thing for months and it's the end of the line for me. Luckily, the AmpliFi Alien Router just came in stock today so I will be switching over to that. Good luck to those who are sticking with this terrible product!
xjn
Mar 07, 2020Apprentice
I was about to order an Alien yesterday also when saw back in stock but after doing some research saw they have not added DFS channel support... the Alien only has two channels for 5GHz so people are getting even slower speeds sometimes since cannot move to unused frequencies yet. Also the WiFi 6 chip on Alien does not allow to change channel yet so stuck on channel it comes with.... gonna wait since seems all these new AX routers aren't ready yet.
mafo5000 wrote:I tried incorperating everyones suggestions and most of them, unfortuntaley, made the router perform worse than before. Turning off smart connect did help but (only slightly) not enough for me to keep the router. I've been messing with this thing for months and it's the end of the line for me. Luckily, the AmpliFi Alien Router just came in stock today so I will be switching over to that. Good luck to those who are sticking with this terrible product!
