allarone
Jun 21, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
cliff344
Aug 12, 2020Apprentice
So after several months of testing, I have to report that this router does now remain functional without the need for frequent reboots. Netgear finally fixed it for the most part after almost 2 years of failed attempts. I do now have my RAX80 in full service. All the functions of this router seem to be fine except 2 things still need addressed. First main issue, is the USB functionality. If you plug in a USB drive, it will kill the routers functionality within 12 hours. It will stop responding and disconnect from the internet. I have tried 3 different USB drives of different brand and size, and it happens with all of them. Second issue (minor) is more geared towards the Apple Nighthawk app. I have 34 devices, and many of my 2.4 wireless devices will show up as wired, and it basically mixes them all up and incorrectly identifies them with the wrong connection protocol. So other than these 2 issues, I am finally pleased with the the functionality of this router after waiting nearly 2 years to get it right. Too bad now the next generation of junk will be coming out from Netgear and this will be almost at "End of Life" status shortly.
- cliff344Aug 12, 2020Apprentice
I forgot to add in my previous post I was testing with the latest firmware 1.0.3.98
- BubbleCatAug 12, 2020Star
Also using 1.0.3.98 in my router.
I ended up factory resetting after the latest update and I agree that things seem A LOT more stable and consistent. I still have a few small quips myself:- My VPN connection on my laptop will disconnect and reconnect frequently while connected to WiFi. Wired connection has no issues
- As Cliff mentioned, the display of which devices are connected isn't refreshed often enough and accurate on which type of connection is being used.
- I still get WiFi drops from other devices in my network and have had to restart the whole router to resolve them (one example is FireStick unable to connect to service despite being on network, then getting disconnected entirely).
- Bigtime68Aug 12, 2020Guide
Mine has also substantially improved. Once in a while, I have to reboot, but overall, it's working well.
- cliff344Feb 06, 2021Apprentice
Well thought I would drop a recent update on my RAX80 status. As of the date of this post, I am running the latest firmware (1.0.3.106). The last few updates have worked well, but I still get a quick flash once in a while that my wired connections drop out for a quick few seconds and reconnect. I get an occasional report from my Samsung TV telling me this. Doesn't seem to be as frequent as in the past firmwares. My biggest issue right now is the USB ports. I have read some people are finding this router is very picky on what drives actually work. I have not had that problem, but my problem is when I connect any of the 2 Western Digital My Passport drives, within about 12 hours or less, I loose all internet and wireless connectivity. Completely locks everything up. I'm not sure if this is a power issue or not, as both drives require the USB power to run them. I used both of these drives on my R8500 without any issues. Maybe somebody can share their USB experiences with this drive?
