shackman48
Nov 22, 2022Aspirant
RAX80 Reservation Table Issues
Have two RAX80 routers and both are providing DHCP address to my devices but the reservation table has wrong IP provided for a particular MAC address. I use DHCP range of 100-160 and devices are cor...
shackman48
Nov 28, 2022Aspirant
Have you used any static IP addresses set ON devices at all? YES, there were 3-4 when I tried to install my entire existing system, but when I started applying devices manually one at a time I did NOT have any items that were static.
For Apple devices be sure to disable WiFi Private IP Address features on these devices. This causes DEV host name to be seen on the Router. IS OFF
What browser are you using? Be sure to clear our all browser caches. EDGE & CHROME, all cache cleared.
Has a factory reset and setup from scratch been performed since last FW update? As I mentioned, tried 3 firmware attempts, reset to factory, and manually tried to install several devices.
Can you post a screen capture of what your seeing on the routers web page? Edit out all MAC addresses first. Given up on this after a week of trying so many things and on TWO routers with no change. Thanks anyway for the help!
Nov 28, 2022Guru - Experienced User
Good Luck.
