ashrahman88
Oct 12, 2020Tutor
Rax80 reverts to factory settings on reboot
HI, I've seen a couple of posts about this, but am at my wit's end with regards to how to fix this issue, if it is even fixable. Have a RAX80, currently on the latest firmware ( V1.0.3.102_1.0.48...
ashrahman88
Oct 12, 2020Tutor
Oh, forgot to mention, I've tried the 30,30,30 reset option as apparently that has fixed the issue on some routers, but to no avail.
microchip8
Oct 12, 2020Master
Might be related to the R7800 where some units use a Macronix NAND chip. There is currently no fix. Also, a 30-30-30 reset has no effect on ARM-based routers, only MIPS ones. If I was you I'd return it or do an RMA
- ashrahman88Oct 12, 2020Tutor
microchip8 wrote:Might be related to the R7800 where some units use a Macronix NAND chip. There is currently no fix. Also, a 30-30-30 reset has no effect on ARM-based routers, only MIPS ones. If I was you I'd return it or do an RMA
Unfortunately had it just over a year.
- microchip8Oct 12, 2020Master
You still have hardware warrenty, no?
Is the hardware warranty not 1 year? I did not do any extended warranty on it.
