ashrahman88
Oct 12, 2020Tutor
Rax80 reverts to factory settings on reboot
HI, I've seen a couple of posts about this, but am at my wit's end with regards to how to fix this issue, if it is even fixable. Have a RAX80, currently on the latest firmware ( V1.0.3.102_1.0.48...
ashrahman88
Oct 12, 2020Tutor
Oh, forgot to mention, I've tried the 30,30,30 reset option as apparently that has fixed the issue on some routers, but to no avail.
Oct 12, 2020Guru - Experienced User
Have you tried downgrading the firmare a version?
Sometimes the newer firmware introduces issues. This could be one.
- ashrahman88Oct 12, 2020Tutor
plemans wrote:Have you tried downgrading the firmare a version?
Yeah, I reverted down to 1.0.3.88, still the same issue.
