ashrahman88
Oct 12, 2020Tutor
Rax80 reverts to factory settings on reboot
HI, I've seen a couple of posts about this, but am at my wit's end with regards to how to fix this issue, if it is even fixable. Have a RAX80, currently on the latest firmware ( V1.0.3.102_1.0.48...
microchip8
Oct 12, 2020Master
Might be related to the R7800 where some units use a Macronix NAND chip. There is currently no fix. Also, a 30-30-30 reset has no effect on ARM-based routers, only MIPS ones. If I was you I'd return it or do an RMA
ashrahman88
Oct 12, 2020Tutor
microchip8 wrote:Might be related to the R7800 where some units use a Macronix NAND chip. There is currently no fix. Also, a 30-30-30 reset has no effect on ARM-based routers, only MIPS ones. If I was you I'd return it or do an RMA
Unfortunately had it just over a year.
- microchip8Oct 12, 2020Master
You still have hardware warrenty, no?
- ashrahman88Oct 12, 2020Tutor
Is the hardware warranty not 1 year? I did not do any extended warranty on it.
