Kev_M
Feb 12, 2021Aspirant
Rax80 reverts to factory settings on reboot
Hi, My RAX80 reverts to factory settings on reboot. I saw this problem on another thread and made some disparaging remarks so I was enouraged to start my own thread by ashrahman88 I have a...
Feb 12, 2021Guru - Experienced User
When it comes to the RAX devices, the latest firmware isn't always the greatest.
they also respond favorable to factory resets with manual reinstalls (not from a backup).
Have you been having issues since you owned it or when did the issues start?
If it just started recently, it might be worth downgrading to version 1.0.3.102 (or earlier) over a harwired connection. Then do the factory reset/clean install.
What gateway is it connected to?
