edsfilms
Jun 14, 2020Initiate
RAX80 SETTINGS FLAW - DO NOT PURCHASE THIS ROUTER
I have had my RAX80 for over a year now, and it's is by far the best router I have ever used, EXCEPT... And this is a big except. Whenever there is a power outage, or I restart the router, s...
frosted1030
Aug 30, 2020Aspirant
I have seen this myself. Created a backup config for this issue.
- TopologyAug 31, 2020Virtuoso
It is possible that power quality/fluctuations are the cause of the problem. You may wish to consider the use of an uninterruptible power supply (e.g., see here); which provides EMI/RFI filtration, surge suppression, and automatic voltage regulation – together with battery backup (using sine wave output).
- edsfilmsAug 31, 2020InitiateDid try the backup battery. I was hoping that with the power always being supplied, this would stop. But this problem happened anytime I restarted the router. It just wouldn’t hold my settings.
