wjdearborn
Apr 18, 2020Follower
RAX80 Setup Problems and any possible solutions needed!
On initial setup of Nighthawk RAX80 I had difficulty with the Nighthawk App. I could not find the Router, no matter what I did - until I discovered the Wi-Fi button. It was not even mentioned in the ...
- Apr 18, 2020
Probably easiest to factory reset using the button on the back of the router.
Otherwise you can plug in via ethernet and access the router that way. In a browser goto routerlogin.net.
kilomikealpha
Apr 18, 2020Initiate
