dixonjd2
Nov 26, 2019Tutor
RAX80 Short Disconnections
Once or twice a day my router (RAX80) will disconnect all LAN inputs for about 1-3 seconds. Not long enough to cause long term issues, but just long enough to disconnect my work VPN or drop me from a...
dixonjd2
Feb 09, 2020Tutor
Hi ubedawg,
I can tell you that it is for sure just wired devices. I have been working with netgear on this for months. We’ve run debug logs to capture when it happens, we’ve tried reflashing at lower firmwares, we’ve even tried a brand new router and modem. It seems to be a problem with the RAX80. Our latest step was to turn off UPnP and that fixed the problem for about a week but it is back in full force again. If you go wireless for gaming (which is what I did) beware of lag spikes. For some reason I was getting insane lag spikes even though my console is a foot away from my router. At least I never got DCed though.
Chocobofarm
Mar 25, 2020Guide
I am having the same issue : short disconnects that only affect devices connected via ethernet cable. I've been browsing through the forums and it's really frustrating to see that this has been an ongoing issue for many users for such a long time. Is Netgear doing anything about it? Users who have gaming consoles or a gaming PC will want a reliable wired connection with the router. Does anyone know if Netgear has acknowledged that this is an issue with the RAX80?
- GabboCHMar 25, 2020ApprenticeAs above, there are many people in the different threads in the forum with exactly the same problem.
I ran Ethernet cable round my house to hardwire TVs & consoles because of the problems the RAX80 has with WiFi connections only to find that the LAN connection was even worse.
I provided debug logs to Netgear but had no feedback.
It is not possible that Netgear don't know about this issue, it's been occurring for so long, but they won't acknowledge any of the problems.
The only solution is to buy a different router.
I am using a Netgear EX8000 extender (WiFi 5) in exactly the same position in my network & it's worked perfectly for months so it's clearly a RAX problem.
Other users have given good feedback with Asus & Archer WiFi 6 devices.
If you want any kind of customer support I'd recommend to avoid Netgear...
