mateverywhere
Oct 20, 2021Aspirant
RAX80 Short Preamble in 5GHz
I've never been able to get my RAX80 to save 'Short Preamble' against the 5GHz network. For the 2.4, it saves without issue.
Using the latest firmware as of today. Not using Smart Connect.
Has anyone been able to make 5GHz work with Short Preamble? How?
- mcleveland92Aspirant
I have not seen or found a soluton for this? Anyone?
- mateverywhereAspirant
No solution, still. Pinging it back up to attention, hopefully.
Other settings are
- AX enabled
- WMM enabled- OFDMA enabled
- microchip8Master
I have a RAX43 and am also unable to set the 5 GHz band to Short Preamble. I think it's a bug somewhere but have not reported it yet
- sachbTutor
It doesn't work here either. Also UPnP is broken on the latest version of the RAX80 (V1.0.5.132_1.0.69)
