droidfan
Jul 08, 2019Aspirant
RAX80 slow Ethernet and wifi
I'm on firmware V1.0.1.58_1.0.24. I have QoS disabled, just installed the Intel AX200 wifi 6 chip in my Dell Inspiron 7568 2-in-1 in the m.2 slot, and tried transferring a file from a powered USB 3.0...
droidfan
Jul 09, 2019Aspirant
I've already installed Intel AX200 driver version 21.20.0.5, dated 5/28/2019, and have selected '4. 802.11ax' for '802.11 n/ac/ax wireless mode' in the wifi chip properties, under the Advanced tab. I've also enabled AX in the router settings. Anything else I can do?
droidfan
Just updated the Intel AX200 driver to 5/30/2019 version 21.20.1.1, and tried transferring files from the USB attached hard drive, and the speed is still capped at 30 megabytes/s. There must be something that is capping the speed. I set the 5Ghz wifi network channel to Auto, so it should find the best channel, right?
