session_101
May 12, 2020Aspirant
RAX80 slow WIFI speeds, LAN is fine
RAX80 Router Firmware Version V1.0.2.76_1.0.35 This just started happening recently. WIFI basically goes to a crawl/slow speed for no reason. I basically narrowed this down to the router. ...
fcano42
May 16, 2020Guide
It is possible that your neighbors have the same wifi channel you do. Try changing the wifi channel.
You google "how to pick the best wifi channel for my router" and you'll find several web pages that will let you map out your local wifi channel usage. Run these at a time when you are having issues (probably neighbors kids waking up and starting their gaming :).
