session_101
May 12, 2020Aspirant
RAX80 slow WIFI speeds, LAN is fine
RAX80 Router Firmware Version V1.0.2.76_1.0.35 This just started happening recently. WIFI basically goes to a crawl/slow speed for no reason. I basically narrowed this down to the router. ...
brianebrown79
May 16, 2020Aspirant
I am having the same issue, disabled AX and on a totally differnt 5ghz channel than anything my attena can pick up (120).
brianebrown79
I actually ran through all of the channels, nothing worked faster than channel 120. I get a around 480 mbps down, on a CenturyLink 1Gbps (940Mbps) fiber connection; using a Intel 9260 chip, connected at 1.7Gbps to the router.
