spikyllama57
Jan 30, 2020Aspirant
RAX80 Slow Wired Speeds vs. Modem
I currently have 1000/1000 service through an ISP called EverywhereWireless. I have my router plugged in to an ethernet jack that supplies the speeds to my unit and from the jack itself, I'm getting ...
zmon
Jan 31, 2020Guide
It's sort of a known issue at this point. https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-slow-speeds/td-p/1802095/page/2
You can enable, then disable, QoS and speeds will go back to normal for a short time. Restarting the router also has the same effect. My own RAX75 just halves the download speed for the most part, while upload is pretty much typical of what I'd usually get.
