coppockm
Nov 02, 2019Guide
RAX80 Smart Connect connecting devices incorrectly
I set up my RAX80 yesterday (V1.0.1.64_1.0.27 firmware) and enabled Smart Connect. All of my devices are connecting, but some (media streamers and laptops) that support and require 5GHz connections a...
Nov 02, 2019Guru - Experienced User
Not using smart connect. To force it, seperate out the ssid's. Many prefer this option so they can ensure their high bandwidth devices are using the 5ghz. i know they're refining smart connect so it might be better in the next firmware version.
TRAFALGAR
Jan 26, 2020Aspirant
I'm hoping a future software arrives soon...right now my experience with "Smart Connect" makes it an oxymoron.
- GabboCHJan 27, 2020Apprentice
Smart connect works fine on my EX8000 Netgear extender (and on my non-branded IAP modem/router).
It is clearly broken on the RAX80 along with all Wifi functionality in general.
I have no confidence it will ever be corrected on this router as the same issues have been around for many many months without any fix..
