Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
GabboCH
Oct 05, 2019Apprentice
I think you are correct because this was the same behaviour I experienced with the RAX80 out of the box (after an automatic update).
Try performing a factory reset & setting up your router again.
This seemed to work for me.
mi2432
Oct 06, 2019Aspirant
Thank you for the reply and I will give that a try witgen the next 2 days
