Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
robledrew
Oct 23, 2019Apprentice
I've been working with various LVL2 techs and (I assume) at least one behind the scenes engineer, and the advice I have received has included:
1) Use old firmware
2) Disable AX
3) Avoid using DFS channels
I'm now doing these 3 things and monitoring the connections. Obviously consumers buy this model because they expect to use AX (the biggest selling point OFDMA), and DFS (for wide band channel utilization = speed) so having to keep these settings disabled really neuters the router.
I can keep everyone posted as to my success but for now you may want to follow suit and disable AX and use non-DFS channels until Netgear figures out what is going on with our routers.
The fact that the same issue occurs in several model numbers makes me think the issue may be in the implementation of the feature itsel f and not a specific hardware configuration, but I'm no RF engineer by trade. Just software.
- thinksincOct 23, 2019Apprentice
I returned my unit to the store. Fundamental flaws like this are inexcusable in an expensive router (I had the $600 TriBand flagship monitor), and just demonstrates that Netgear rushed this WiFi-6 series to market in an effort to gain marketshare over competitors like ASUS.
I've been a lifelong Netgear user but this is my last Netgear product. I'll try another WiFi-6 router in 6-12 months when the technology has matured, but I won't be selecting a Netgear model.
- mlotov83Oct 24, 2019Star
I'm having the same issues. Did you get something else?
- ClibertOct 24, 2019StarWell thought my issues were resolved think again. EAX80 shows strong connection to RAX80(all lights are white) yet it is so slow I can’t stream. This is refociléis for a 250 dollar extender. They are at opposite ends of a 800 sqft house so maybe 50’ away. All other devices are ok. Needed it for 2 devices that aren’t WiFi enabled. Guess I’ll be selling this garbage. It is unusable. My RAX80 rebooted in the middle of a business call today too.
- wayno4Oct 23, 2019Aspirant
This is the 2nd time of trying to post, seems my disconnect issues prevent it posting successfully the first time.
I am not able to create a support case, as my 90 days ended last month, however I would like some comment from Netgear support please.
As with others I purchased what should be a top of the range device for a not insignificant amount of money, right now it's useless to me. The disconnects are happening almost every minute at their worst the latest firmware v1.0.1.64_1.0.27 that I applied this morning!
I'm not using Smart Connect, or any of the DFS channels and have disabled AX, with no improvement seen. After 3 efforts to download an old version of the firmware, I'm now going to retro-fit that in the hope I can actually get some work done this afternoon
Netgear support - how are you going to resolve these issues which are impacting your customers? My prefenerce at this stage would be a full refund so I can buy a product that actually does what it says it should!!
Given the lack of traction to resolve issues so far, I encourage everyone to comment on Netgear Facebook and Twitter feeds if they exist, to complaion about this.
