Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
digitsnbits
Nov 12, 2019Apprentice
Hi All,
I have a RAX80 that doesn't have most of the problems all of you are experiencing but it does have quite a few problems including smart connect not working.
Just want to say after some experiments and a couple of purchases there are AX routers out there that have all the features like smart connect, solid AX WiFi, good range working flawlessly.
Funny thing is so far the best I've run across is actually one of the cheapest AX routers available.
AX3000 similar to AX4, not quite as fast as the RAX80 but very close and a whopping $129 at Walmart. If these guys can do it it's hard to justify Netgear charging top tier prices for hardware that just doesn't work as it should.
Whixson
Nov 15, 2019Aspirant
Rax120 with frequent dropouts on my iPhones. Running SmartWifi with latest firmware.
