Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
xjn
Dec 18, 2019Apprentice
GabboCH wrote:Today I tried the firmware 70 (despite the confirmation from netgear support that it does not address any of the Wifi connection problems).
With this firmware I couldnt even stay connected to the LAN port (this was experiencing connect-disconnect-connect-disconnect) issues.
Perhaps these problems are not Wifi related at all but instead the router soft-boot-looping?.?:?
Either way, I dont recommend anyone else to try the 70 firmware unless you have free time to waste.
Just when you thought the RAX80 couldnt get any worse...... (:facepalm)
It is working okay for me. Still have QoS issue, random LAN disconnects, etc. Also had to factory reset it twice after update because speeds were being capped to under 30Mbps... unfortunately I can not return since bought in February. Having been putting up with same issues all year... I swore of Netgear in past due to issues and now regret my purchase somewhat. I think may south to new Ubiquiti Alien AX router soon when have funds.
GabboCH
That doesn't sound like it's working ok if you have LAN disconnects & a speed cap from QoS...
Rather, like many of us, you have paid a lot of money & have no choice but to limp on with it....
- xjnDec 19, 2019Apprentice
Rather, like many of us, you have paid a lot of money & have no choice but to limp on with it....I spoke too soon... I agreee with poster above that newest 70 firmware is somehow worse.... have done 6 factory resets now and it's constantly dropping to 30Mbps, internet connection drops, etc... ridiculous
I did some more troubleshooting... seems Comcast is having trouble in my area along with Netgear QoS issue so that is why my speeds are so slow. Once Comcast is fixed will report back on if can get QoS issue to stop.
- DJ_Phat2000Dec 20, 2019Star
Last 2 days, WiFi is been finicky. Seems to be up, but some devices don't connect while others do.
Had to reboot it, and it took a long time before it connected to everything agian. I have various deivices like smart lights, wifi remote control, tablets, laptops, computers, printers, phones, and watches, and consoles, smart TV's etc.
When it doesn't work via WiFi, but something else does. It's annoying as can be.
PLEASE FIX THIS THING!
