Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
NullByteMe
Jan 23, 2020Aspirant
Well Friends, there is an issue with these routers from either a Hardware standpoint, or in my opinion a Firmware issue. I tried my first RAX 35, wired and wireless speeds were fantastic, but starting day 2 wired and wireless devices across both frequencies were lost. Attempted channel transmission changes at Netgear supports urgence, on both 2.4 & 5 GHz, as well as well as lowering MTU to 1492 from 1500.... No change. I Just received a replacement direct from Netgear yesterday ( original ordered from Walmart on Black Friday, hence the purchase, half price ) the new one is doing the same thing, same issues. Once a day, internet is lost. Strangely it remained today on two devices running 2.4 GHz wifi, as well as several security cams on same freq.... but hardwired D.T. no joy. ( a variable I experianced on the first router as well) Now I didnt retain the original firmware that came on the unit, ver. (V1.0.2.48_1.0.1)I upgraded to the only available Firmware available V1.0.3.62_1.0.1.... and problems are back.... wish I would've used the original just to test..... Im gonna give this a few more days, hoping maybe the techs will release a new firmware to resolve this.... if not Im going back to my old Asus AC 68u workhorse... Im an IT professional, so Im not a layman on these matters, but the last thing I want is calls during the day from the Mrs. about wifi being down, or having to trouble shoot networking issues when I get home. A power cycle of the router resolves the issue, but again its replicating daily. Has Anyone not upgraded the factory shipped firmware using these routers? And possibly not had these issues?? As a side note, Ive just replaced my modem with a DOCSIS 3.1 thinking that was the original culprit.... wrong. Arrrrrrgh!!
NullByteMe
hate to reply to my own post, but checking logs noticed this... [DoS attack:ACK Scan] from source: 192.168.1.12, port 63433, Thu,Jan 23,2020 18:36:40
several instances seen... However I assumed this a possibility initially, and Ive monitored for days with wireshark and Kali through airodump to confirm and CANNOT verify this log.... No trace seen in my recon, only seen this in the logs.... plus DOS would not effect my hardwired device - and would knock out all wireless on one or possibly both frequencies.... intermittent loss is strange... can be done but doubtful knowing the surrounding neighbors and assuming their "tech" savvyness... Very fluent in pentesting personally, and Cannot verify this so im not sure of its validity.... WTF netgear. Are these units compromised from factory?
