Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
macgyverx
Sep 18, 2020Aspirant
I've been strugling with the same issue for many months. The router started off great, rock solid and no issues, but after some time and a few firmware upgrades, it started dropping connectivity here and there and got steadily worse to the point where it was doing it multiple times a day, only a hard reset woud fix it. Here is what finally worked for me (your mileage may vary). I set the transmit Power Control (Basic > Wireless) for both 2.4 and 5GHz to 75% (still gave me coverage in the house), also set the router up on 4 small 2 inch high boxes, one under each foot, becase it was running hot (intake vent is on the bottom and the I only hear fan on a power cycle). So far its been two weeks without a single drop. It would not surprise me that as the router ages (while running hot) the components also age and begin to perform poorly. We'll see if this is a short term or long tern fix. This is why this model gets great reviews out of the box, wonder if that would change if the reviewers used it daily for over a year.
