Greekst
Aug 13, 2019Tutor
Rax80 smart connect issue wifi dropping
Ive been having issues with my RAX80 since purchasing it , if i leave the router with the seperate bands (2.4ghz &5ghz) it runs fine but once i activate smartconnect all i get is intermittent connecti...
Emyshorts
Jun 26, 2020Aspirant
I've owned mine for a year, wifi drops-Tvs, phones, laptops, can reboot and it settles down, but will return. Basically, you turn off AX and SmartConnect and the wifi is stable. These tech features don't work on this model with my equipment. I have a copier connected wifi and it keeps a message log of what is happening, every hour the wifi would drop, re-join, go for 45min to an hour and drop and rejoin. I really believe the router decides to swap 5g-2.4g constantly. Figures since turning the smartconnect off resolves the issues.
I really believe Netgear has become the microsoft of the industry...push out a product to say your first at this tech, but that may not work and rely on firmware/software to fix. They have been unable to fix on this one.
2l82xlr8
Oct 16, 2020Tutor
I have found the issue is the latest firmware.
When I install the firmware prior to it, NO DROPOUT.
Keeping it that way until NETGEAR gets their **bleep** together!!!
- MarcB44Nov 19, 2020Aspirant
Just bought the AX8...at first start I've accepted the suggested firmware upgrade
I configure it as an Access Point and activate smartconnect with same SSID for 2.4 and 5.0GHz Wifi...
Wifi is unstable on my macbook pro, it drops, it come back, 2 minutes later it drops again and so on...
It's like buying a car with a motor that stops every miles...
Any tech expert here ? Should I send back this piece of xxxxxx ?
- GabboCHNov 19, 2020ApprenticeIf you read the other posts there are some thing to try which work for some people but not for others.
Most of these issues involved turning off function you paid for, SmartConnect, AX etc
I recommend to send it back if you can.
The same issues have been present for many users for more than 1 year & there is no response from Netgear at all. - MarcB44Nov 19, 2020Aspirant
Seems you're right, but it is unbelievable...
My firmware is V1.0.3.102_1.0.48 (the latest I guess)
is it the same with all Netgear AX router ?
is the "reconnexion" by design with AX ?
which cheaper router should give the same power and antenna quality to cover a big house in 2.4 GHz ?
- GabboCHNov 19, 2020ApprenticeSome of The other RAX line use a different chipset so I guess should perform differently than the RAX80.
However there are similar reports of problems with the rax120 for example.
I am using a EX8000 (tri band) Wi-Fi 5 access point instead of the RAX80 and have similar coverage and zero problems, but I have no Wi-Fi 6 capable devices. It is 100€ instead of 300€..!
Several others commented that other Wi-Fi 6 manufacturers like ASUS are not without their issues too, so for me going down the Wi-Fi 6 is a bit of a gamble still as the technology is new.
If you read all the reviews these days, everyone just says "this router is amazing". You will struggle to find anyone saying any product is bad these days, even bigger channels or magazines.
I decided to invest in a strong Wi-Fi 5 router for now until the new standard is better understood & products improve. - 2l82xlr8Nov 19, 2020TutorFigured out the issue!
Turned off Smart Connect, and set up wifi according to IPhone preferred settings... and NO MORE DROP OUTS!!!
Thanks to a Saavy APPLE TECH... - MarcB44Nov 19, 2020Aspirant
Great but what's are "iPhone preferred settings" ?
- EmyshortsNov 19, 2020Aspirant
Don't foget
You are here because your setup was not working correctly according to what the manufacturer made you believe...troublefree wifi 6 capability, wonderful wifi/lan peace and unity.
In reality your city was burned.
If you turn these super expensive fuctions you bought the router for, all is well. Its a no brainer according to netgear.
- GabboCHNov 19, 2020ApprenticeExactly, if you have to turn off smart connect for the device to work correctly, it is a work around not a solution.
I have smart connect enabled on my EX8000 and it works without issues.
The same for my ISP non branded router.
Smart Connect is not a new feature, I've had it for the last 5 year's and it works flawlessly.
Its just one of multiple things the doesn't work properly in the Netgear RAX80.
