bemak187
Oct 30, 2020Aspirant
RAX80 Timezone/NTP settings wont change
Hi.
Got an issue with my RAX80. I am in the UK so timezone should be GMT in NTP settings. It is showing as GMT -12 International Date Line West. I went in and chnaged it to GMT UK, hit apply, looked like it was saving and then just defaulted to GMT -12. Does this every time I try. I'm on the latest firmware and the router is only a couple of days old.
Thanks.
- bemak187Aspirant
Issue SEEMS to be fixed by multiple router reboots.
- Christian_RNETGEAR Employee Retired
Hello bemak187,
Thanks for providing an update regarding your issue..
Christian- Manatee1714Aspirant
I've got the same issue with NTP settings not being saved. Circle stops working as a result. On latest firmware. Have done the usual factory reset etc and multiple reboots but still doesn't work for me. On latest firmware.
Known bug? Seems as though there are many complaints about the RAX80 NTP not working.
