gwbaker
Jul 26, 2019Guide
RAX80 to CM1100 Link Aggregation questions
Searched already, answer not found. RAX80 connected to CM1100 cable modem with gigabit service. When I connected the WAN and LAN1 ports to the CM1100 ports 1 (WAN) and port 2 (LAN1), both the...
- Aug 07, 2019
I guess I had a gremlin infecting my system for a while. It is now working just fine, and I have no idea why. Nothing changed.
FIRST let me acknowledge Netgear's AWESOME technical support. From reading my forum post, tech support reached out, obtained my contact information and my odd availability schedule. They worked around my time and called me at my home to help figure this out. One of the trouble shooting requests was to check the router internet light to see if it indicated connectivity. When I reconnected the ethernet wires and re-enabled everything to report my findings, suddely it is worked as it should.
I am not sure why. I changed nothing. Not even the ethernet cables were changed. So, all is well even though I do not know why.
KUDOS goes to Netgear's tech support department. They went WAY beyond in an effort to help me.
gwbaker
Jul 28, 2019Guide
More information in hopes of illicting a reply other than my own.
RAX80 router is now connected to a Netgear GSS116E 16 port gigabit managed switch. The link between the RAX80 and GSS116E is using two ethernet cables connected to ports 4 and 5 on the rourter with LACP 802.3ab enabled on both ends. The dual ethernet link aggregation is working just fine from the router to the switch.
Still no love with link aggregation between the RAX80 router and the Netgear CM1100 cable modem? STILL LOOKING for an answer as to why I cannot get this to work (see orginal post for full question).
HELP! --- Anyone?
schumaku
Jul 29, 2019Guru - Experienced User
Ingeresting work-around. But curious: What's the point of running a WAN LAG on a Gigabit service? Or is the service allowing higher bandwidth?
