gwbaker
Jul 26, 2019Guide
RAX80 to CM1100 Link Aggregation questions
Searched already, answer not found. RAX80 connected to CM1100 cable modem with gigabit service. When I connected the WAN and LAN1 ports to the CM1100 ports 1 (WAN) and port 2 (LAN1), both the...
- Aug 07, 2019
I guess I had a gremlin infecting my system for a while. It is now working just fine, and I have no idea why. Nothing changed.
FIRST let me acknowledge Netgear's AWESOME technical support. From reading my forum post, tech support reached out, obtained my contact information and my odd availability schedule. They worked around my time and called me at my home to help figure this out. One of the trouble shooting requests was to check the router internet light to see if it indicated connectivity. When I reconnected the ethernet wires and re-enabled everything to report my findings, suddely it is worked as it should.
I am not sure why. I changed nothing. Not even the ethernet cables were changed. So, all is well even though I do not know why.
KUDOS goes to Netgear's tech support department. They went WAY beyond in an effort to help me.
gwbaker
Aug 07, 2019Guide
Christian_R
Aug 07, 2019NETGEAR Employee Retired
Hi gwbaker - Happy to hear! Thanks for taking the time to provide an update to the rest of the Community!
~Christian
