JimTheGreek
Oct 29, 2021Tutor
RAX80 too slow
Too slow via Ethernet Got Spectrum 400Mbps (new modem). Max speed via Ethernet 80Mbps. If I plug PC directly to modern I get 480. Also, I cannot use the Rax80 MAC address, I have to use my PC on t...
- Oct 29, 2021
Problem solved. It was the QOS setting. Turned it off, full speed! Plus, reboot w/o the router, then connected the router and it allowed the router MAC address!
Thank you all!
BTW: I apologize for posting this in a language I don't speak, it was a mistake, sorry!
But, what's interesting, it's not showing up under my posts, yet, Netgear community sent me a badge update. Cool!
JimTheGreek
Oct 29, 2021Tutor
Thank you all!
Nov 01, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
