Dotdodd
Dec 30, 2022Aspirant
RAX80 unable to detect internet (overseas)
Hello, I'm currently working overseas and I'm having trouble getting my RAX80 to connect. When I was in Spain it was simple to just plug the router directly to the modem via the internet port and I wa...
Dotdodd
Dec 31, 2022Aspirant
I don't have my RAX in AP mode, but this is what I'm currently doing. I turned off the WiFi broadcast of the TP link and plugged the internet port of the RAX into port 1 of the TP link. It seems I'm getting full speeds, but I had an issue with my PS5 not connecting before I needed to change the DNS settings
Jan 02, 2023Guru - Experienced User
If you're using both devices in router mode, it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
