adam8a
Jul 08, 2020Follower
RAX80 Unable to reserve IP addresses
I'm using Firmware Version V1.0.2.76_1.0.35 My Router lets me add addresses for reservation, but it does not honor those reservations. When the MAC address I reserved for a certain certain IP conne...
ITSysMan
Feb 02, 2021Aspirant
Was this ever resolved? I am having the same issue.
Address reservation is unreliable. Not only does it not honor it, but it also sometimes shows IP addresses that are definitely not assigned to the mac address in question (verified by access the web page of the device and it would be something completely different from what is expected but also from what is shown on the router interface-found the actual IP by doing a netscan). This adds a degree of uncertainty when troubleshooting and trying to find the root cause of issues. Willing to try an updated firmware or an older one that is known to be reliable. I wish Netgear would focus on reliability of basic functionality before trying to add what i consider IMO to be useless marketing features. Currently running V1.0.3.106_1.0.50.
antinode
Feb 02, 2021Guru
> [...] Address reservation is unreliable. [...]
Perhaps, and, when dealing with Netgear router firmware, almost any
bug might be plausible, but a more likely cause would be the presence of
another DHCP server on the LAN.
- ITSysManFeb 03, 2021Aspirant
good idea about another dhcp server causing conflict. But in my case, the two other device that could offer DHCP are turned off (one pihole running in a vm and a netgear wifi extender.)
Now that I think about this a little more, there might be an Cisco OOEP device that I have no control over that was provided by my wife's employer. I wonder if DHCP service is enabled on it and causing issues. I have no idea how those work exactly but my understanding is that they isolate her computer from my LAN and connects it to her work network. I may have to contact them but I doubt they will be responsive.
- onurich01Feb 03, 2021Tutor
As the OP, I have to say this issue is closed for me. I have given up on Netgear hardware/firmware. This is my 3rd rotten egg from them. I switched out and have found great success elsewhere. The tech support for netgear is horrible, the firmware updates are horrible. I'm glad to have put it behind me. I'm only sorry for the sunk cost in this hardware.
- CLIFFFFFFFFFFFApr 12, 2021Aspirant
my RAX 20 is doing the same thing and im about to throw it out the window. waste of 150 dollars. and NETGEAR DOES NOT WANT TO SUPPORT YOU UNLESS YOU PAY FOR THEIR SUPPORT. WHAT A JOKE .
