MonteMossman
Jul 30, 2020Aspirant
RAX80 UNCONNECTABLE BUT WORKING FINE
My RAX80 is working great - Internet, printer, streaming, cloud, gaming but I can't get into the router itself. I browser the IP address (Chrome) and I get "Page Not Working." My Nightwawk App says ...
Jul 31, 2020Guru - Experienced User
What modem are you connected to?
If you're on windows, open a command prompt and type "ipconfig" the default gateway would be the routers ip address if you're not having a double nat issue.
MonteMossman
Jul 31, 2020Aspirant
Modum is an Arris Surfboard 6190. Perhaps double NAT is possibility. I have a secondary router supplying a sub-net. Perhaps my main router is in bridge mode while the secondary modem is supplying the Internet connection. Is there any way to get into the Nighthawk to see if that is the case? BTW - default IP is as expected - 192.168.1.1 which sends no data.
- ablickleJul 31, 2020Guide
I have had issues connecting to the router and the app saying "Not Connected" when everything was running fine with my RAX80 before. Turning router off for a few minutes fixed it every time. It is a weird issue though...
- plemansJul 31, 2020Guru - Experienced User
is your secondary router running in access point mode?
