vjaychowdhary
Feb 09, 2020Aspirant
RAX80 Unstable
I have enabled smart wifi that merged 2.4 and 5 channels but I am facing unstable speeds. I am not sure if it is due to frequent switching of device between 2.4G and 5G or something else. When it is w...
Feb 10, 2020Guru - Experienced User
some homes don't function well for smart connect. Its half pointless in my area due to 2.4ghz interference. My 2.4ghz speeds are bad because there's so many networks and the router tends to stick devices on the 2.4ghz a lot.
so I don't use it when I'm running a regular router.
Have you noticed wireless issues with it disabled?
