mcoop1988
Feb 24, 2023Tutor
RAX80 Updated to Firmware Version 1.0.10.140 and Wifi speeds dropped
I have a Nighthawk RAX80 and I updated to the most recent firmware update // Firmware Version 1.0.10.140 Wifi speeds dropped from 800 up and down to barely over 100. I tried reverting to the o...
Feb 24, 2023Guru - Experienced User
1. You weren't hitting 800mbps over 2.4ghz. the 60 is more in line with what 2.4ghz is capable of
2. the 250mpbs over 5ghz, what device are you testing on? And how far from the router are you ? What link speed do you get when connected at that spot?
3. Did you try a factory reset?
4. What modem/gateway are you connected to?
