mcoop1988
Feb 24, 2023Tutor
RAX80 Updated to Firmware Version 1.0.10.140 and Wifi speeds dropped
I have a Nighthawk RAX80 and I updated to the most recent firmware update // Firmware Version 1.0.10.140 Wifi speeds dropped from 800 up and down to barely over 100. I tried reverting to the o...
mcoop1988
Feb 25, 2023Tutor
- I tested on a iPhone and iMac and I was getting 800 up and down on 2.4GHz. I don't have smart connect turned on for my router so I can manually select between 2.4 or 5GHz. The specifications for my router allow me to theoretically get up to 1.2Gb on 2.4GHz from 15 feet away. Before calling someone a liar, maybe check the specifications if you're trying to help?
- The router is maybe 50ft away in the next room and I have it hard wired to my iMac.
- I didn't try a factory reset as it'll be my last option.
- The modem is one provided by AT&T: Model BGW320-500
michaelkenward
Feb 26, 2023Guru - Experienced User
That would break the laws of physics.
Tested how? The Nighthawk app measures the speed through the modem, not over the WiFi.
That looks like a gateway (modem/router).
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply modem/routers that won't work in bridge mode. There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
