lplarry
May 15, 2022Tutor
RAX80 version 1.0.6.138 update cause loss of local access
After updating firmware to 1.0.6.138 I no longer have local access to the router. Only access is Anywhere using the Nighthawk app. I cannot login via web browser to upload previous firmware version...
lplarry
May 16, 2022Tutor
I was reinstalling using app.
Connected to Spectrum cable modem.
I've tried connecting using ip address and routerlogin.com.
The app shows no local available. After I reboot there is a short time I get a local connection, but it disappears before I can upload a rollback the previous firmware.
May 16, 2022Guru - Experienced User
what spectrum modem?
After the factory reset (push and hold reset for 7-15 seconds while powered on) are you able to access it using the web browser?
If so, try that method of setup. I'm not a huge fan of the app
- lplarryMay 16, 2022TutorDOCSIS 3.1 Modem / Voice Equipment
- plemansMay 16, 2022Guru - Experienced User
that's still not a model. That just says you have a docsis 3.1 modem with voice.
its like a mechanic asking what car you have and saying, it has 4 wheels and seats 6 people.
Not trying to be an pain but sometimes people put a modem/router combo device before their router and it causes issues.
Its why we ask for a specific model number. the label should have it.
- lplarryMay 16, 2022TutorModel EU2251 is what Spectrum provides.
