avi1000
Aug 25, 2020Follower
rax80 wifi drop once per day
Hi. I have netgear rax 80. It was running for 75 days with the previous firmware v1.0.3.88 with no problems at all, until a few days ago when I upgraded the firmware to v1.0.3.98. Over the past few da...
Aug 25, 2020Guru - Experienced User
One thing you can try next time is a factory reset. Its usually the first step if there's issues after a firmware upgrade.
