SergM__64's avatar
SergM__64
RAX80 WiFi not detected by MAC mini , Iphone 12 mini, Iphone 11 pro, Samsung android 7
Hi all, yesterday trying to permit to my Mac mini the Wifi signal, just turned off and turned on only problems, only via cable is possible to access to internet. I've tried to chnge channel both 2.4 GHz and 5 GHz but no change and further I've ost connection with all mobile phone at home with error autheticaion or PSW, but the password is remeined the same. Please help, there is also a pandemic situation and it's necessary for my kids connecting to the school and for my job. Urgent support Thanks.
This device is expensive but I did not get back great functionalities
1 Reply
  • schumaku's avatar
    schumaku
    From the factory new or factory reset system, all what's required is either adding the SSID/network name and the security key / wireless password as printed on the device label.
    Had played with some wireless access control or the like?
    For simplicity - and lack of any explanation what was done - I tend to suggest doing a factory reset of your router, and re-configure it from scratch.
