SummerDellTx
Sep 25, 2021Aspirant
RAX80 will not save any applied configurations after applying and restarting
I started noticing a couple weeks ago my AP (AC1900) dropping off frequently and the only remediation was to restart the RAX80. I applied all recent firmware updates and that didnt fix the AP drop is...
DarrenM
Sep 28, 2021Sr. NETGEAR Moderator
Hello SummerDellTx
I suggest contacting support could be a hardware issue with it not saving your configs after a power reset.
https://www.netgear.com/support/contact.aspx
DarrenM
SummerDellTx
Sep 28, 2021Aspirant
The device is 2 years old, shows out of warranty now. Im unable to reset and rebuilt it now due it not saving anything after a reboot. I had no choice but to buy a new router. This RAX80 was expensive so Im frustrated that it died like it did. Unless Netgear has anythign to offer me in the form of replacement then additonal followe-up by me is worthless. The new other brand router works fine. Uhggg. Thanks for your response.
