Pad70
Mar 24, 2019Tutor
RAX80 wired connection slow - reposted from general router
Nighthawk RAX80 replaced a Nighthawk R8500. Cable modem is the CM1000. Provider is Cox gigablast at 1 gb/s down and 35 mb/s up. Setup is plain vanilla with no QOS. Internal speedtest measu...
lestart
Feb 03, 2020Tutor
Unfortunately I have exactly the same problem with my RAX80, I also get to ca. 470 downspeed and have 1 gig fibre. In the router internal speedtest measurement over 900, with a different modem, measurement over 900 with the RAX80 (which is really no bargain) 470, it would be nice if there is a solution. Of course only 1 device with Cat7 was connected during the measurement, directly without switch etc...
