mnarlock
Nov 26, 2019Aspirant
RAX80 Wired Connection Speeds
I apologize if this is in the wrong board. I have a brand new RAX80 and am connected to an XFi modem in bridge mode. If I run speedtest from the Nighthawk GUI (advanced>Setup>QoS Setup>Take a Speedte...
GabboCH
Nov 27, 2019Apprentice
There's the same issue reported for the RAX120 where the lan speed drops by about half.
There were some suggestions that turning off QoS fixed the problem but this didn't seem to be a solution for all.
Just another issue in the long list for the RAX devices....
Cookmaster301
Nov 28, 2019Aspirant
Yeah I just put this router in and I get 450 hardwired and 70-90 wireless even on 5G
On 2.4 it’s only like 25
This thing is a turd so far
- mnarlockNov 28, 2019Aspirant
I did find that turning on/off QoS really did help. My speeds are as expected now.
- Cookmaster301Nov 30, 2019AspirantI tried that also and didn’t affect it at all. Maybe this thing just sucks. Guess I will put my ole trusty luxul back in
- xjnNov 30, 2019Apprentice
Try going into setting and enable QoS.... wait a few minutes.... then disable QoS. After doing that should get full speeds... if not try it again and should fix it. If you reboot the router have to do it again. Seems QoS gets enabled even though it shows as disabled so only way to turn it off is to turn it on, wait, and turn it off in GUI.
