GregJ_
Apr 03, 2019Follower
Rax80 Wired ethernet connection slower than wifi speed
Changed to a new Nighthawk AX8 and getting only 10Mbs download from the ethernet connected computer while all wifi connected devices are getting 178Mbs download. I've tried rebooting everything sever...
Christian_R
Apr 09, 2019NETGEAR Employee Retired
Hi nullie,
What devices are you using to test your speeds? Were you able to run a speed test directly to the modem?
~Christian
Retired_Member
Apr 10, 2019I have been using a windows 10 desktop pc and a macbook pro 15" (2018) for wired speedtesting and an iphone x and samsung galaxy s10 for wifi speeds. but again - and I can't stress this enough - before I rebooted the device the speeds were great. I had the RAX80 for about 2 weeks and everything worked fine with superior speeds; after rebooting the device once it seems like a speed cap at 500Mbs kicks in affecting only the switching ports.
Connecting a cable from my desktop pc to the modem directly gives me network speeds around 920-930Mbs, just like when I'm doing a network speedtest in the router's webfrontend itself.
- xjnApr 10, 2019Apprentice
I had same issue and was able to fix it by factory reset. The issue came back after update to new firmware. I did not want to reset so I toggled QoS on and off. I left QoS off and I am getting 940Mbs on wired and up to 840Mbs on WiFi on my laptop. The issue has not returned for over three weeks now.
- dragonpakApr 12, 2019Tutor
I had the same issue after the new 56 firmare, thanks to xjn tips, I switch on and off the Qos setting, now back to 940mbps. and the MIMO setting for wireless doesn't work, once switch on , the wireless will just drop off all connected devices.
- Retired_MemberApr 14, 2019
business trip... sorry for answering late.
that actually solved my problem! speed is back to normal. thank you xjn!
- Christian_RApr 16, 2019NETGEAR Employee Retired
Hi nullie,
We're glad to hear! We recommend marking xjn's comment as a solution as it may help others who may experience the same issue.
Hope you had a good business trip!
~Christian
- Christian_RApr 10, 2019NETGEAR Employee Retired
Hi nullie - Thanks for the update. Have you tried performing a factory reset to see if it resolves your issue as stated by xjn.
~Christian
