Pad70
Mar 24, 2019Tutor
RAX80 wired performance
Nighthawk RAX80 replaced a Nighthawk R8500. Cable modem is the CM1000. Provider is Cox gigablast at 1 gb/s down and 35 mb/s up. Setup is plain vanilla with no QOS. Internal speedtest measures ...
xjn
Apr 10, 2019Apprentice
I had same issue and was able to fix it by factory reset. The issue came back after update to new firmware. I did not want to reset so I toggled QoS on and off. I left QoS off and I am getting 940Mbs on wired and up to 840Mbs on WiFi on my laptop. The issue has not returned for over three weeks now.
