Pad70
Mar 24, 2019Tutor
RAX80 wired performance
Nighthawk RAX80 replaced a Nighthawk R8500. Cable modem is the CM1000. Provider is Cox gigablast at 1 gb/s down and 35 mb/s up. Setup is plain vanilla with no QOS. Internal speedtest measures ...
Pad70
Mar 24, 2019Tutor
Follow up from first post. I replaced the RAX80 with an Orbi Router. The Orbi significantly outperforms the RAX80 with wired connections. Speedtest shows 968 mb/s down with the Orbi and 460 mb/s down with the RAX80. I'm returning the RAX80. It's clear to me that the RAX80 is not ready for customer shipment at this time.
JoseAndres041
Apr 10, 2019Luminary
It could just be the QoS. You need to make sure that you have properly configured it.
- Mjohnson4580Apr 11, 2019TutorI dont think Qos has anything to do with it cause it happens regardless of wether its active or not.
- xjnApr 11, 2019ApprenticeYes, it happens when QoS is off. It as if the QoS is on but the visual indicator says it’s off. Toggling it to on and then toggling it to off makes it switch back to off position. I have done it twice and it worked both times. Not sure why QoS turns on by itself, but it clearly does... the speed get with QoS is the same speed see when the issue occurs, around 500Mbps which is half of my Gigabit connection. It also may be related to the names of devices not saving properly also. Can use access control to set names and a few days later all the saved names revert to default.
