thatrevguy
Jun 09, 2020Guide
RAX80 Wireless Devices unable to see ethernet connected devices.
This is an odd one... I upgraded firmware on RAX80 to V1.0.3.88_1.0.41 and now none of my wireless devices can reach ethernet attached devices on same local network. On the flip side wireless dev...
- Jun 10, 2020
It looks like that firmware was just pushed out 5/29.
And you've tried the factory reset.
I'd open a support ticket with netgear if you're still within warranty just so they're aware of the issue.
I'd then downgrade to the prior version of the firmware.
Jun 10, 2020Guru - Experienced User
- thatrevguyJun 10, 2020Guide
Downgaded to firmware V1.0.2.76_1.0.35 and problem went away. Didn't even reset the router.
- plemansJun 10, 2020Guru - Experienced User
Glad to hear you got it working!
Did you get a chance to send a notice to the support team so they're aware of the issue?
Just sent one. THanks again.
