Lildogz96
Sep 17, 2022Aspirant
Rax80 won’t reset using the button
I purchased a used rax80, and I cannot get it reset using the button. I tried the 30-30-30 rule and that worked briefly, but when I changed some settings it reverted back to the settings it had before...
Sep 17, 2022Guru - Experienced User
Try the 30/30/30 again. When you get back into it, reinstall the firmware to it (before making any changes so you can get into it) and then do a factory reset from within the gui.
- Lildogz96Sep 17, 2022AspirantI’ve tried as you suggested several times, and each time upon reset within the gui, the router acts as if I never reset it in the first place.
