Lildogz96
Sep 17, 2022Aspirant
Rax80 won’t reset using the button
I purchased a used rax80, and I cannot get it reset using the button. I tried the 30-30-30 rule and that worked briefly, but when I changed some settings it reverted back to the settings it had before...
michaelkenward
Sep 17, 2022Guru - Experienced User
Lildogz96 wrote:
I purchased a used rax80, and I cannot get it reset using the button. I tried the 30-30-30 rule and that worked briefly, but when I changed some settings it reverted back to the settings it had before reset.
I suspect that this needs more details about your network. What else is on it?
Then again "used" may also mean broken.
If a standard factory reset fails, there is, as plemans says, a more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If recovery reset fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation, timing is important, as are the exact details for the commands and prompts you see. It can take several attempts. So if you are forced to use TFTP try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
