JcaezzaAspirantAug 05, 2019RAX80 WPA3 Support I would like a definitive answer as to if the RAX80 supports the WPA3 standard.
JcaezzaAspirantAug 06, 2019Thanks for the response. So it should come at some point as a firmware update? Does anyone know of the timeline for its release?
plemansGuru - Experienced User to JcaezzaAug 06, 2019should come as a firmware update. No idea as to the rollout plans.
