rabiddawg
Jun 23, 2019Follower
RAX80
RAX80 has intermittent wifi and internet.
using my R8000 router solved the issue!
thinking i wasted money on this junk.
I have not had a good experience with the RAX80, it has been a waste of money and time, in the end I have gone back to my fritzbox and CISCO wireless and UBNT wireless access points which are QA tested and just simply work. Support have done nothing to be able to help and now the product is out of warrenty and has never really worked correctly. Been a very disapointing experience and will be thinking twice before i purchase another netgear product or recomending it to others.
- IrvSpMaster
rabiddawg wrote:RAX80 has intermittent wifi and internet.
If you posted over on the forum for this router (https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6) and explained the RAX80 problem (or looked at the theads which seem to be having problems) someone might be able to help you out?
- myerswMaster
Yup, return if you are within the return window and get from a different vendor.
Netgear right now, IMHO has lost their way when it comes to firmware. They do not seem to address known problems and the QA of the firmware seems to be lacking.
There are folks on this forum that will not like this suggestion, just so you know.
- Christian_RNETGEAR Employee Retired
Hello rabiddawg - If you recently purchased the device we recommend utilizing your complimentary support using the following link.
https://www.netgear.com/support/default.aspx
~Christian
