todonal
Mar 06, 2020Tutor
RAX80
My ISP has a 192.168.1.254 IPv4 and this new router is running at 10.0.0.1 for its IPv4. I tried to reset the IPv4 to a 192.168.1 scheme using a smaller subnet mask but the router config bounced. Is ...
Christian_R
Mar 12, 2020NETGEAR Employee Retired
Hello todonal,
Would you mind letting me know if you have more than 1 router connected to each other.
Thanks,
Christian
todonal
Mar 12, 2020Tutor
This Nighthawk is running thru an ISP gateway from AT&T using the IP address I mentioned in my original post. I turned off all wifi functions in the ISP gateway. I believe I might know the answer to my question but if someone cares to offer something I will compare to my solution and see if we agree.
- Christian_RMar 13, 2020NETGEAR Employee Retired
Hello todonal,
Please try setting the gateway to modem mode only to see if your issue persists.
Christian
- todonalMar 14, 2020Tutor
I fixed it. I tried to set up the AT&T gateway to config this RAX80 as a Cascade Router with the new IP and subnet but it didn't want to cooperate. I am good now. Thank you
