ky123mt
Aug 18, 2020Follower
rax80
I just did firmware update everything seamed to go ok. I have wifi everything is normal but I can not log into the netgear app once I log into app it shows the router using "connect via anywhere acce...
PatrycjaG
Aug 19, 2020NETGEAR Moderator
Bonjour ky123mt,
Bienvenue sur le forum Netgear :)
Pour plus de cohésion, pouvez-vous reposter votre message en français ?
Bonne journée,
Patrycja
Equipe Netgear
- Christian_RAug 24, 2020NETGEAR Employee Retired
Hi ky123mt,
May you reinstall the Nighthawk app and power cycle your router.
Thanks,
Christian
